Old 06-30-2016, 01:50 AM   #3 (permalink)
mikesheiman
Ok, so it tapers in too quickly...would it actually be better off as a hatchback e.g. no taper at all? I know even some hatchbacks get about 0.3 CD.
And I think I see what you mean about the sides. As in they push air up, only to curve into an area where it's quickly pulled down a bit, thus causing a vacuum/turbulence area? How much CD would you guess that issue alone costs and what's a good way to fix it (simply keep sloping upward and very gently start curving downward to meet the very side/tail area)?
The Following User Says Thank You to mikesheiman For This Useful Post:
aerohead (07-06-2016)
