Crafty. The Ferrari solution doesn't look like it would do much. Compare to this:
Edit: I looked at the Ferrari article. There are two new examples of Ferrari using external ducts on the rear.
This went right over my head, woops. think ducting is a good solution, but only when integrated into the design. It would be difficult to add underneath a car that wasn't designed with it in mind, like most projects on here. Its doable, but building down would kill your ground clearance, and building up would require cutting floorpan. I do intend to do ducting to my radiator and out the hood, but cutting holes is a big commitment. I might try and nudge airflow out behind the front wheels so it doesn't hang around the engine bay and pass under the car. I might buy some of the famous garden ending after work and get creative. But testing it will take patience
