Old 06-30-2016, 11:19 PM   #44 (permalink)
oil pan 4
Originally Posted by RustyLugNut View Post
And the results are erratic. Software has a lot to do with this. Short term fuel trim is the best indicator. Using a variable output electrolyzer is imperative. Use too much HHO and the engine bogs if timing is not adjusted and the engine computer does things to compensate. Use too little and nothing happens. There is simply too much going on to even begin to "tune" for HHO. The work of pfgpro and others who have the ability to control their engine tune may answer more than simply dumping the gas into the intake of the common car.
Sounds like the HHO ruins the gasolines detonation and pre-ignition resistance.
This effect could be achieved by adding diesel to the vehicles gasoline or raising the compression on a gasoline engine.
