Old 07-01-2016, 06:37 PM   #21 (permalink)
Natalya
Engine-Off-Coast
Natalya's Avatar
Red 2000 Insight (2017 through 2019) - '00 Honda Insight 5MT
90 day: 64.72 mpg (US)
Red 2000 Lithium Insight (2020) - '00 Honda Insight LTO
90 day: 71.76 mpg (US)
@Brucepick:
Ecky's diagram, a few posts above, shows the VSS is split, sending a separate signal to the speedo and to the ECM. I wired the switch after the split on the ECM side, so the speedo should work fine. My next task is to get a different resistor on the timer to make it pulse more slowly (target is 2hz) and to power it with a 5v source from the car. There's two pins on the ECM connector I want to look at.
The Following User Says Thank You to Natalya For This Useful Post:
brucepick (07-01-2016)
