Old 07-02-2016, 05:38 PM   #9 (permalink)
serialk11r
Originally Posted by spacemanspif View Post
Been keeping an eye on the Focus load readings past couple days. Idle load is high 20s or low 30s. Seems kinda crazy that idling cost that much power....
Yea, but the engine is spinning at only 700rpm when idling, so the fuel burn is not that high.
Contrast that with having the car in gear going down a hill, where you keep load at 20% at 2500rpm, that's a much bigger waste of fuel. That's essentially what P&G is all about.
Also load might be calculated as manifold pressure vs. atmospheric pressure, but variable valve timing might be limiting the intake volume per stroke.
