Here is a suggestion that I seriously considered when I did my V2.0 Aeroshell. Find a local custom boat builder that does custom fiberglass work. You build the blank out of foam, carve it, shape it, etcetera. Then pay them to lay glass on it.
I ended up just doing my own fiberglass work despite having close to zero experience. The actual fiberglass part turned out well, I should have then taken it to a body shop for final bondo, prep, and paint as that part only turned out acceptably but not as nice as it should have. Darn having no patience and not much time.
