Old 07-12-2016, 11:03 PM   #3 (permalink)
oil pan 4
For cylinder deactivation to really be worth it you need to be able to collapse the lifters and close both valves in the cylinder. With the valves opening and closing trying to move that air in and exhaust out it feels like the engine is misfiring badly.
What I did to double fuel milage on my carbureted suburban is:
Tune the engine for lean burn during cruise, lean at or near WOT is bad, you need to run rich during higher power situations.
Adjust the timing properly, does it have EGR?
Use EOC.
In the winter I took the fan off my engine to speed up warm up times and I am going to switch over to electric fans. In AZ, during the summer in the city an electric fan may not be a good option for you.
I also made a switchable warmed thermostatic and cold air intake, the thermostatic side is too small for WOT use.
With fuel injection you should just be able to use a traditional warm air intake.
You can change to a numerically lower rear end too.
