Old 08-07-2008, 09:09 PM   #10 (permalink)
nascarnation
A lot of this depends on the gear and control layout of the transmission.
Because there potentiall could be a big difference between the engine speed (low)and the trans output speed (high), and what gear range is selected from neutral to re-engagement.
Some control strategies will hold the engine above idle in a neutral coast to reduce trans load on re-engagement.
