That third graph is what I was worried about Phil. It plots the height, not the angle and shows an increase as the height goes above a small value.
Opposite over Adjacent = 7/96 =.072916
angle is 4.17 degrees.
The ground clearance is 12", and yes it would have radiused corners.
If this long rising diffuser helps, I'd make a 4 sided boat tail instead of the simple two sides, two rounded corners, and top.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
