Old 07-18-2016, 01:23 AM   #5 (permalink)
botsapper
PSmodder lurker
'was culling through my magazines and ran across this.I couldn't find a thread on it at EcoModder.
I GOOGLED it and found this article
Aston Martin clears the air on new DB11's 'AeroBlade'
The C-pillar intakes collect and funnel air to special tubing and distributes it on a wide rear exhaust vent behind a pop-up Gurney flap to create a 'virtual spoiler' or a rear deck air curtain. @2:15-3:15.
F1 'black magic' aerodynamicists have been using special ducting (F, W,and S-ducts) to create stall conditions and lowering drag on front wings in max speed straightaways or 'sculpt' blown exhausts under the diffuser to gain more downforce on turns. In aviation, they use blown-flap systems to create higher lift in slow speed conditions. They use blown air vented broadly over the rear upper edge of extended flaps. Just like aircraft mechanics' concerns, they will require more maintenance and have duct blockage & rear deck drainage problems.
The Following 2 Users Say Thank You to botsapper For This Useful Post:
aerohead (07-19-2016), BamZipPow (07-19-2016)
