Old 07-19-2016, 02:33 PM   #9 (permalink)
Grant-53
The process involves using a casein industrial glue to bond sheets of metal to plywood. The glue is rolled on and the panels are pressed under hydraulic pressure for several days while the glue cures. More to the use of ecomodders is the availability of aluminum honeycomb or nomex honeycomb. If composite materials are applied to shapes made from the sheets of honeycomb the vacuum bag is used. Note that Coroplast is now available in honeycomb sheets.
The Following 2 Users Say Thank You to Grant-53 For This Useful Post:
freebeard (07-19-2016), Xist (11-21-2017)
