I don't think heating the fuel will make much if any difference during normal operation.
The reason I am doing it is for when its like 10'F out side and I need to get my old carbureted pig going.
That way I can heat the fuel so it vaporizes better when its real cold out and so I can keep the density of the gasoline closer to what it is in the summer time. Since I am running carbureted the fuel density effects the mixture.
The density between cold and warm fuel is only between 1 and 2% but the more variables I can get rid of the better.
Most of that doesn't apply to fuel injected.
