About flame speed...
From wikipedia:
https://en.m.wikipedia.org/wiki/Flame_speed
The flame speeds are not the actual engine flame speeds, A 12:1 compression ratio gasoline engine at 1500 rpm would have a flame speed of about 16.5 m/s, and a similar hydrogen engine yields 48.3 m/s, but such engine flame speeds are also very dependent on stoichiometry[2]
That has to do with turbulent versus laminar flame speed, as you can imagine in a cylinder head with swirling air and a spray of gas from the injectors the flame front won't be laminar for long.
The flame speed you described was based on laminar burn.
Even so, hydrogen does burn considerably faster.
When the pressure builds up the mixture starts to explode or even detonate, propagating the explosion front at speeds close to or surpassing the speed of sound.
In that too hydrogen will increase the speed.
I see no reason why a tiny amount of hydrogen should increase the flame speed by much, but it may lower the explosion treshold somewhat, which can be troublesome.
In water one in ten million hydrogen atom will be a loose ion because of the polar properties of water molecules but in a gaseous state almost all hydrogen will be in molecular form; H2. These need to be broken up in the burn before anything happens. Protons in water are irrelevant for the burn process.
When you heat up the electrolytic cells to 80°C and you feed it to the intake it will contain a large amount of water vapour. If you feed it in behind the throttle plate and the engine is at low load the vacuum may be strong enough to make the water in your cells boil by itself.
Adding steam may reduce pumping losses and therefore help the engine tick over, improving efficiency.
I'm running out of time here but you see, there are some loose ends in your story. Science is about tying them all together, proving that every step inevitably leads to the next. Scepticism is the tool to look for weak points in a theory; if there are viable alternate explanations then the theory loses credibility.
Scientists will first try to falsificate their own theories before they put them out in the open; such a shame to put your name on it if it can be blown away, a simple oversight maybe.
If you do science you should have your answers ready for proper criticism.
This is no science lab so there will be criticism that is not properly formulated or reasonable.
That unfortunately is a given. Take it with dignity, explain it away once and link to the explanation whenever the same point comes up again.
But most of all, stick to the topic. This explanation of yours is your best yet. It should be in its own thread instead of a discussion about etiquette. Now it sidelines that discussion.
