Old 07-21-2016, 01:34 AM   #27 (permalink)
Natalya
Engine-Off-Coast
Natalya's Avatar
Red 2000 Insight (2017 through 2019) - '00 Honda Insight 5MT
90 day: 64.72 mpg (US)
Red 2000 Lithium Insight (2020) - '00 Honda Insight LTO
90 day: 71.76 mpg (US)
Procedure to get Auto-Stop under normal driving in a manual:
- Warm Engine (water above 130°F)
- IMA not background charging
- Outside temp above freezing
Easiest way:
- Be above 40km/h
- Press brake pedal & decelerate
- Throw into neutral while still holding brake
- Auto Stop should happen around 35km/h
-- It might happen higher (up to 40km/h) if you are decelerating really fast
So, the sequence is brake, neutral, go under 35km/h
With my EFAS (still WIP) circuit so far the only method I have to make it work is as follows:
- Be Auto-Stopped
- Press clutch switch button (tells car clutch is engaged)
- Activate EFAS circuit
- Drive and accelerate like normal, except there will be no IMA assist or regen
- Get to desired speed or top of a hill
- Put in neutral
- Hold down brake pedal (or I use brake switch)
- Auto Stop SHOULD happen
-- If it does not release the clutch switch
- Now you should have Auto Stop engine off coasting at whatever speed
That's the only way I can get it to work. I think it has to do with the pulses. I recently removed a resistor to make the pulses slightly faster. Originally I had 57kohm of resistance, but removing the resistor brought me down to 47kohm of resistance. Because I still wasn't getting the desired results, tonight I added 20kohms, so now I'm up to 67kohms of resistance which should slow the pulses more than they were originally. I have not gotten to test this, we will see how it goes.
Desired functionality:
- Be at like 80kmh
- Hold brake switch
- Auto Stop
At some point in that sequence I have to activate EFAS switch, I don't know when I need to be pressing the EFAS switch. I suspect that with slower pulses I'll get more leeway. Auto Stop is pretty weird, it doesn't always happen when expected
Like maybe you're at 20kmh and you throw into neutral you won't get it, but if you press brake and decel quickly you will get it, but if you let off the brake then engine restarts unless you engage the clutch switch, but if you started with the clutch switch engaged it might not want to Auto Stop until you're going slow//decel via brakes AND you release clutch switch.
Try wrapping your head around that situation. I hope that slower pulses will make it more likely to want to AS.
