Old 07-24-2016, 04:12 PM   #252 (permalink)
orengomotors
Well, This year the rules had changed and it's compulsory having a bottom,belly on the car to prevent driver feet or legs to touch the ground.
So, i have to build a " flat bottom" before august 16 to be able to compete.
My question is, it's possible to build a bottom for the car that also improves the aerodynamics?
any tips?
this is going to be like another little subproject, like the nose and the suspension.
thank you!
edit:
i have designed that so far, it's ok? the diffuser has to be 5 degrees for optimum drag?
The Following User Says Thank You to orengomotors For This Useful Post:
aerohead (07-25-2016)
