Old 07-25-2016, 11:05 PM   #7 (permalink)
Stubby79
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
They don't want us to know how much it weighs or any dimensions, as the "specs" area on their site contains no specs.
Works fine for me...?
Base specs:
6061 corrosion resistant aluminum frame with rear suspension
Hemp & soy composite body
Vinyl doors with zip up windows
Full flooring with removable heel well inserts
Impact resistant polycarbonate windows
Programable 48v 750W power system
16ah Lithium Ion battery
Fully adjustable cockpit (pedals, seat, handlebars)
20mph top speed
25 mile range (without pedaling)
5 Amp integrated charger (plugs into any standard wall outlet)
Full street lighting (headlights, brake lights, turn signals, running lights)
Reverse
Cruise control
Regenerative braking
Horn
USB charging port
Keyed power switch
Sturmey Archer 8 speed rear hub
Sturmey Archer 90mm drum break front hubs
Avid BB7 rear 200mm disk brake
Oversized 2.3" Kenda K-Rad tires on Alex DM 24 alloy rims and heavy duty spokes
6 cubic feet of rear storage
Transformable passenger seat for 4 cubic feet more rear storage
6 Standard Colors: red, orange, yellow, blue, green, white
Dimensions:
Length: 99"
Height: 54"
Width: 44"
Track width: 42"
Weight: 195 lbs
Options:
600 watt heater
Battery warmer wtih dashboard mounted temp sensor
Additional USB/12 volt power ports
110W roof top solar panel
Up to 3 more additional 16ah batteries for 100+ mile range per charge
Interior lighting
Wider tire and wheel options
Custom coloring
The Following 4 Users Say Thank You to Stubby79 For This Useful Post:
aerohead (03-03-2021), Frank Lee (07-26-2016), freebeard (08-20-2016), NeilBlanchard (07-26-2016)
