Thread: Water vapor?
Old 07-26-2016, 11:47 AM   #9 (permalink)
Hersbird
Dark Egg - '12 VW Touraeg
Thinking more about the setup described and my Navy distilling unit operator days, if you can get enough vacuum on the container and then run exhaust through it (sealed off inside tubes), I wonder if you could get it to boil. You would then get much more vapor as "cool" steam. I have no idea if this would be better or worse then just using water which will flash to steam in the combustion chamber anyway.
