Old 07-28-2016, 03:15 PM   #139 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
With the sketchy logging roads I go up, I wouldn't want the Prius any lower than it already is unless I had a way to adjust ride height with airbags. The underside is already very used, with some of the mounts holding on the front under tray completely worn away.
When I was driving through Montana on some dirt roads I found myself wondering what it would be like to lift the Prius a little (not that much, maybe 1-2"), stick some knobby tires on it, and then surprise all the Jeep guys.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
