Old 07-29-2016, 02:25 AM   #8 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Kach22i
I hope I haven't offended
2
Agreed reduction of A is a large gain. in this old dodges case loss will occur apon repars being made . Ill explain . This model of dodge uses an aproxamitly 3" tall 0 rete spring rubber for proper ride hight. Theas last (from what I've read) aproxamitly 100,000 mi 10-15 years. My truck on the original rubbers @275,000 and 25years the rubber is about as thick as a pice of paper. = ~ 3"lowerd in the front. Stock rear /~ 17" under the hitch. So whin i get this defect repaired the A will grow.
If the Montana roads and 4-8"ice ruts hadn't taken out 3 Ball joints in 6 months, I would not be considering raising the front end. Cause and effect. I think the Ball joints are operating out side an accepted operating angle causing failure.at a price of $100.00 ea upper and 75.00usd ea lower purchased yesterday will in stall in near future. With theas NASCAR spring rubber less the splits ABA testing will be labor intensive but valid. I will have to do a life span test to determine. If the accelerated Ball joint wear is worth the extra FE of the lowered front
I would rather keep it low and find some geometry corrected control arms . Then 4 link and bag the rear for load compassity.
Point#3
Appearances can be deceiving.
Some of my design requirements to call a truck a truck it must maintain the ability to:
1 haul 1 cord (4'×4'×8' neatly stacked) fire wood, wet/green Oak ~ 3,000lbs . (This will fit under the cap as in the wrapped load pic the top duse not nee to tuch to bed this load travaled 800 mi with no trouble at 69-75mph)
2 have at least a class 3hitch with a min of 10,000lbs WD
If theas 2 are not true itis not a truck, then its a glorified car and the mod isnt practical.
Hence all modds must pass this litmans test
For my cap
easy and quick removal by 1 person (v1.2 =35lbsV1.0=21lbs sub 5min removal, it takes longer to tie it down than to r&r the cap, with my current cap. Note: it duse help to point the truck straight into the wind for installation as the windvaine effect can be strong
Point 4
Allready discussed my method of lowering .. more details to solve this lost compassity. Add some ride hight controls mechanical lenkage or go high-tech decade old tec magnetic, these are both load compensateing .
Eg of a random load that found its way to my truck to day
Moons would help .
Larger mirrors are already wanted . For towing safety.
Sealing off the cab i finally spent the $3 on pool noodles on tusday on Wednesday I got a personal best on my 200mi mpg test route 29.3south and 27.26north an aproxamitly 1.5mpg improvementin each direction . I have wanted to rebuild the headache rack when I first built it (I should have measured twice and welded once .to close the gap to .5-.325" .
Nice truck .
Like they say no pic no happen so
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following 3 Users Say Thank You to gumby79 For This Useful Post:
BamZipPow (08-04-2016), skyking (08-04-2016), t vago (07-29-2016)
