Old 07-29-2016, 09:03 PM   #12 (permalink)
redpoint5
90 day: 29.78 mpg (US)
Originally Posted by me and my metro View Post
I ran our 60 liter Diesel genset yesterday for its monthly exercise... it burns 125 gallons/hour at rated output of 2 megawatts. The four huge turbos sure sing at 2 megs.
You need to cut back on your electrical consumption. Consider turning off the PC when you aren't using it, and switch to CFL bulbs.
Originally Posted by spacemanspif View Post
What are your cars idling at?
The Prius doesn't idle, or at least during the few times it does, the data isn't relevant because it's in warm-up mode, and purposely wasting more fuel than it needs to.
My Acura TSX 2.4L I4 engine idles at 25% engine load with the manual gearbox in neutral, and parking brake set (no brake lights on), no HVAC. Timing advance bounces around 9 degrees, but I'm also running the minimum octane instead of the recommended 91. Fuel consumption is 0.18 gal/hr.
The relevant info is instant fuel consumption.
I'd sure be curious if there is any difference from when I had the stock pulley ratios installed. I didn't find this site and get a gauge until after I had swapped it out.
