Old 07-30-2016, 02:50 PM   #6 (permalink)
TimK
330i Rag Top - '05 BMW 330i M Sport
I did some testing today, on my local 2 way test road, I did testing at 40-55mph. Same tyre pressures as last time, and same brand of fuel.
The results show a calculated gain of 0.5mpg in the testing, however, it was gusty today so that may have showed less gains then there would be in identical weather conditions.
However, I did a 30 mile run on a familiar road cruising at 65mph, and with the occasional moment at 70-ish mph to overtake quickly. The result was 40mpg UK, 33mpg US. There was wind around though so I'll reserve judgement, however the wind direction was across me, so not a tail or headwind.
So the initial results at high speeds look good, I would expect to get 31-32mpg US normally in those conditions, so it's possible I've gained 1.5-2mpg at highway speeds with the partial grill blocks and achieved my goal of 40mpg UK.
There is less wind noise at the front so I think drag is reduced to some degree.
I will see what happens next time I go on a run to see if the mpg contiues to be a couple higher than normal.
