Old 07-31-2016, 09:42 AM   #252 (permalink)
Bill the Engineer
Bill the Engineer's Avatar
Originally Posted by California98Civic View Post
A clean garage is the necessary handmaid of sanity sometimes. The hole for the gas port I am imagining will draw fire from enthusiasts (not that they should matter much on this). An alternative routing of the gas tank and such was too complex, maybe dangerous, yes?
As I said in an earlier post, the old Firebird filler neck was just a pipe with a vented cap. The Prius V filler neck has a number of vapor recovery tubes which would be difficult to re-route to the center of the rear. In addition, There is no good path to route them under the car due to other suspension and body parts.
This is what I will be using on the fender at the gas fill. It is from a salvaged 2009 Prius.
The rectangular door of the Gen II Prius with its convex shape was a better choice than trying to use the round concave door from the donor Prius V.
Bill the Engineer
The Following 5 Users Say Thank You to Bill the Engineer For This Useful Post:
aerohead (06-19-2020), California98Civic (07-31-2016), mcrews (07-31-2016), RedDevil (07-31-2016), Xist (07-31-2016)
