Old 07-31-2016, 11:41 AM   #419 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Well the nitrous testing is done.
Did ABA testing and with nitrous activated seen around a 8% increase in fuel mileage. This was with a decrease in ignition timing of 4* and a decrease of injector flow of 4% and a decrease in BSFC of 5%.
All in all it did what I thought it would do and I didn't see anything new. I will be testing N2O WOT next with some changes from the ordinary. My plans are to run a much leaner A/F ratio then normal. It will be a two stage system with a 75 shot from 3000 rpm to 8500rpm and then bring in the second kit a
150 shot from 6000rpm to 8500rpm.
Did some test hits today with the slicks back on.
Pressure Gradient Force
The Positive Side of the Number Line
