Old 08-01-2016, 08:45 PM   #18 (permalink)
freebeard
Originally Posted by mcrews
Stalking much?
As for myself, I'm here because there is a dearth of new threads.
Poodwaddle -- That's the best thing to do with a zombie thread feed it braaiiins.
This is something that someone here could/should test. What is the best home-made tab shapes and angles. It would have to be someone with a sloped back window and someone who has regular enough commutes to get accurate results.
Go all Mythbusters on it. Commuting may not be the best test environment. I like the idea of a long tow cable with a streamlined tow vehicle and a 'vehicle in tow' sign in the middle so people don't cut lanes into it. Then with a simple spring scale and a dashcam you could get data independent of the drivetrain completely.
Also tuft testing and titrating gas from a graduated cylinder.
