Thread: Jet Ski Circles
Old 08-07-2016, 04:49 PM   #4 (permalink)
redpoint5
90 day: 29.78 mpg (US)
Originally Posted by ChillyBear View Post
Sounds like its running lean. "Running strong" is often a bad thing on a two stroke lol. They run best right before the pistons seize....and they idle high. Case leaks/bad reeds can do that too.
If it's been parked for a while, that could be a very real possibility. If you have dual fuel pumps, I'd make sure the pulse port is clear, and that the first pump is clean, or that the pilots aren't clogged.
Jetski's are detuned, but It risky to fire up a two stroke right out of storage and go hard on it IMHO.
I was thinking more about this comment, and it doesn't seem like it could idle faster by running lean. How does less fuel result in higher idle and more power?
I'd think my problem is simply the idle setting, or the throttle return spring not closing the throttle entirely.
Originally Posted by jamesqf View Post
Perhaps I'm belaboring the obvious here, but you could remedy both problems by just trading it for a kayak :-)
I have 2 creek boats and an inflatable kayak. I'm considering buying another jet ski since my trailer holds 2, although I might just transport one of my creek boats on it to the lake. It would be annoying to go any distance since it turns too easily and doesn't track, but that's what I've got.
