Old 08-08-2016, 02:04 PM   #30 (permalink)
freebeard
How does the air flow over a Luton bump? Does it...
Neither. Any surface exposed in the direction of travel experiences a positive pressure gradient. The air sitting undisturbed at A or B has only two choices, sideways or up. Start with 20 streamlines that are all put into competition. Air under the bump is going to move sideways and wrap around the A-pillar. Within a fraction of an inch the air is gripping the body. That's skin friction. At the distance you've drawn the streamlines air is interacting with air is interacting with air, in a [diminishing] fractal recursion. Wind tunnels want 8-10% blockage to get an accurate rendition close to the body.
The only time air moves forward in relation to the body is in the wake, within recirculating separation.
_________
How would you get from square tubing to a finished surface? Sheet metal seems logical. When you built the Kayak was there a lot of tapering the strips necessary? I guess you could do them in bulk. I've known a person who breathed a lot of resin fumes and then croaked.
All four edges of the roof need some radius. Forward facing edges a minimum of 4% of the gross width, typically about 4". 1/4-round down the sides. At the back it makes no difference, but you might as well do that too so it all matches.
Here are some experiments I did with a material called Polymetal. It is an aluminum/plastic/aluminum sandwich. The same joins could be done in sheet metal. Rolling sheet materials is actually easy, the problem is finding rollers long enough for big pieces. Three 10' steel pipes and six skateboard wheels jammed in the ends would suffice.
Note the bottom one has a radiused edge with no framing. It could be sandwiched around a piece of angle iron if that's needed.
