Old 08-08-2016, 10:11 PM   #14 (permalink)
oil pan 4
Using 2 of the 3 phases would work from a functional stand point but might not provide enough power to weld aluminum. It takes a lot of amp to weld aluminum. You can only get about 1/2 to 2/3 the power out of an alternator when using 2 of 3 phases depending on if its a delta or wye wound stator.
