Originally Posted by Frank Lee
The Owner's Manuals I've looked in recommend to drive straight away.
I do that the vast majority of the time. I believe in the faster warm-up while driving gently theory. I'll putz down the street at barely above idle speed, then still go slow in top gear until the temp gauge moves (which happens pretty quickly- FAR quicker than the time most people around here idle via remote start).
If it's -30F I'll let it idle while I'm scraping the windows, and that's about the only idling time my engines ever see.
Agree totally. The only reason to idle for warmup is if the vehicle is iced / frosted up and it is unsafe to drive it. If it is really freezing a brief idle (1-2 mins max) helps to get a bit of chill off before loading the engine up.
Simon
