Old 08-13-2016, 07:15 PM   #10 (permalink)
MPGeo
MPGeo's Avatar
MPGeo - '93 Geo Metro Base
90 day: 67.51 mpg (US)
Weight Reduction PHASE 1
So I purchased a hanging scale because I was curious and wanted to know the actual data... real weight #s rather than guesstimates.
So the scale came in the mail this morning, I've weighed everything I've removed and I have been surprised by the weight of some items, and overall I have been pleasantly impressed with the results...
Total PHASE 1 Weight Reduction = 112.27 lbs.
Here's a list of everything removed, along with the actual weight reduction per item:
A/C System
-complete A/C system + hardware delete (except evaporator) 23.36 lbs
-A/C engine mtg. bracket, hardware & idler pulley 5.95 lbs
Seats
-passenger seat + hardware delete 30.73 lbs
-driver seat replacement mod (12.06) lbs
(this seat mod added weight... but also much needed comfort)
-rear seat bottom section + hardware delete 8.60 lbs
-rear seat top section+ hardware delete 16.78 lbs
Seat Belts
-rear seat belts + hardware delete (2lg + 2sm) 5.26 lbs
-rear seat belts cover plastics (2lg + 2sm) 0.25 lbs
Plastics
-kick panel plastics (2) 0.31 lbs
-under door/ entry plastics (LH & RH) 0.62 lbs
-rear seat plastics (LH & RH) 3.26 lbs
-rear trunk area speaker plastics (2) 1.45 lbs
-trunk area /shock tower cover plastics (LH & RH) 2.34 lbs
-trunk area /under rear window/ hatch area plastic 1.40 lbs
-trunk area /hatch plastic 0.94 lbs
-all of the removed plastic mounting hardware 0.25 lbs
Carpetting
-carpet delete 8.41 lbs
-trunk area carpet delete 1.60 lbs
-spare tire hard cardboard cover delete 2.47 lbs
-under spare tire insulation/black plastic matting delete 2.63 lbs
-(2)front & (2)rear factory carpet matts delete 7.73 lbs
A/C systems delete
Seats, plastics, carpeting, seat belts & associated hardware delete
ID:	20365   Click image for larger version
ID:	20366   Click image for larger version
The Following 3 Users Say Thank You to MPGeo For This Useful Post:
igo (10-07-2016), Joggernot (08-14-2016), thepunisher (08-14-2016)
