In finland there was a plan in the 90's you could get tax reductions if you installed a aftermarket cat. the system had a lambda controlled valve to suck in extra air for the cat. I wonder how this system works, is it a air bypass thingymajig like in scooters?
If you don't make any mistakes in your life,
life itself will be a f*ckup.
With Volvo to Valhalla and back!
