Originally Posted by RedDevil
Lemme try:
What I did:
- Ctrl-click on the links to open them in a new tab
- Go to that tab
- Right-click on the image
- Select the 'Open link in a new tab' option
- Go to that tab
- Right-click on the image in the new tab
- Select 'Copy image address' or 'Copy image URL' (mine is Dutch so that wouldn't help you)
- Go to the EcoModder message edit box
- Click in the Image icon ( which is the yellowish rectangle with two small greyish mountains or pyramids and a blob in the upper right corner)
- Paste the copied address/URL in the picture address selection box.
- Preview, correct, repeat etc.
HTH and keep up the good work!
Cheers,
Bart
I wish I could thank you more then once!
I knew I had done it before but couldn't remember how as it has been sooo long!
Im a little ashamed right now being an IT Administrator..
-Adam
