If I continue to let the temperature climb, the coolant will overflow into the bottle. Eventually it will boil over entirely.
Letting it run a little hot led to the original engine having a warped cylinder head gasket and needing to be replaced. I don't want this new JDM to go the way the original engine did.
I wish it were only the gauge, because then, as you mentioned I would be ready to roll without any changes.
