Old 08-16-2016, 01:34 PM   #20 (permalink)
MPGeo
MPGeo's Avatar
MPGeo - '93 Geo Metro Base
90 day: 67.51 mpg (US)
This morning at the early wee hours of the morning... I found this on ebay for $160 shipped. I fell for it and bought it..
"1.0L. 3Cyl. 1993 Geo Metro XFI Computer 33920-60E63 , XFI Camshaft with cam card from Delta camshafts and timing gear up for sale. All three units are in excellent working condition."
Also today I brought block back from machine shop... They had a bit of an incident with their tooling in the center bore... so they wound up having to sleeve the middle cylinder for free... and they had to deck the block to ensure sleeve install and in the process found that the block itself was warped. They wound up having to shave block an estimated 0.007"-0.010" to be correct warping... The sleeving and decking was free since they were correcting there mishap.
So now I have a fresh 0.020" bore, fresh hone, 1 fresh sleeve, and one more of the 65 mods listed... a shaved block
The down side: Because the block was warped, I had to check the head... and found I have a burn valve...
SO any suggestion on what will be the best option FE wise on my valves? increase diameters? stainless? any other head work suggestions that I should consider since I have to rework head anyways?
ID:	20382   Click image for larger version
ID:	20383   Click image for larger version
