Old 08-18-2016, 12:05 PM   #39 (permalink)
kach22i
Originally Posted by serialk11r View Post
So turns out that Thai hardtop doesn't have seals...because it goes OVER the stock soft top. The stock soft top frame is quite heavy and would be something I'd rather get rid of, so back to the drawing board.
I wonder if you could take off the convertible frame/seals and just use some standard automotive seals from your local NAPA store as the interface between the hard shell top and windscreen frame/body/side glass.
Weather proof 3M double stick tape perhaps could be used.
I mention NAPA because our local store seems to carry the stuff (basic stuff) other stores do not. I'm sure if you need some exotic profile you could find something on-line or special order it.
