Originally Posted by MPGeo
For around $130 - $150 you can find you a good quality, good flow rate 12v electric water pump... why not eliminate your pump pulley all together?
Nevermind $130, I'd direct drive the stock pump with a $20 electric motor if I could.
Unfortunately, this is what the serpentine belt looks like:
If the belt skips the water pump, the alternator pulley would have very little belt to pull it since it would only have maybe 100 degrees of wrap. I am not going to take that risk.
