If the hinge line were 2-3" lower so the top part tilts in, or...
If the hinge line is out at the edge of the cap so it's swing is down and out, or...
If the hinge arm was offset like a car door hinge, or...
If there was a trick 4-bar linkage on the inner eave of the cap holding onto the edge of the window....
Are you going to go for brass or black anodized finish, or what?
Those are all workable ideas. I want to keep things as simple as possible so I don't want to do any complicated hinging system. Dropping the hinge a few inches would probably be the simplest overall solution, but then I will be cutting into my rearward visibility. It will also make it harder to crawl in and out of the bed which is already going to be tricky as I will have a raised sleeping platform.
I haven't decided what finish I am going to use. The window handle and key locks I got are chromed. The piano hinge I have is just bare aluminum. I might get a different hinge or paint the one I have. I will probably mock it up as is and see how it looks.
