I do want to add screws, and add washers under the ones already there, when I get time to... I drove the car today, about a 110 mile round trip, from home to Weston and back... On the way out, UG reported 38.8mpg to Glenville, and 42.3 from Glenville to Weston(75* ambient temp outside), and then on the way home, with 85* ambient temp, I averaged 46.7 from Weston to Glenville, and 41.5 from Glenville to home... Stopped once on each of the return trip legs(UG stayed active) so the averages could have been higher, but still, nearly 47mpg cruising at 55-ish mph, and way over 40 on what is my normal commute home from work... The engine was warm for those trips, but I'm shocked nonetheless...
Cruising load at 55mph(flat road) has dropped from ~50%, to around 47-48%, with instant MPG readings solidly in the mid forties...
My current Ecotec project...
My last Ecotec project...
