Old 08-19-2016, 05:49 PM   #59 (permalink)
freebeard
Originally Posted by myself
If the hinge line is out at the edge of the cap so it's swing is down and out, or...
Consider steel strap hinges with the hinge line below and forward of the eave line, with the leaves normally open. As the window swings open [up to 45° above horizontal] the leaves close, and there is a magnet to hold each one.
Tune the magnets' strength and if you forget and drive off with the window up, the air pressure would push it closed.
