Old 08-08-2008, 05:56 PM   #10 (permalink)
skyl4rk
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
Hoi Roman
Drivers in NL tend to drive fast and the streets are quite busy so it will take a lot of driving skill to improve your fuel efficiency. Try to keep the motor in lower rpm ranges and if no one is behind you, coast to a slow stop. The less you have to brake, the better.
As a friend in Nijmegen told me: A good driver never uses his brakes.
Nissan Versa Aeromods
