I would love to clean out the EGR valve and say it made a difference. But I cannot, for the life of me, find the electrical connector. I've looked all around where the EGR is and no electrical hookup for it is to be found.
On the note of maintenance, I am going to be changing trans fluid, doing a coolant flush, and replacing the thermostat after I run through this tank and get some numbers from it. I did the first half of the trans fluid change on the tank before I started modding. Will also replace the fuel filter.
Also, my brother is suggesting I get some seafoam and apply it to the throttle body. Any thoughts on this?
