Originally Posted by Raysp30
Can't seem to find anything that would be the fuse I'm looking for. There is no fuel injector fuse or a PGMFI fuse. Anybody able to help locate on an 89 crx?
If not, anybody have other ideas for a good kill switch method? The only one I'm still able to find that I know I can do is the fuel pump, and I don't really want to cut that one.
Use the wires on 87a and 30 on your Injector resistor power feed. Will work the same way. I ended up changing mine to this after writing how-to. I believe the injector resistor on your car should be close to brake booster and look like this.
