Old 08-27-2016, 12:07 PM   #11 (permalink)
oil pan 4
Problem with laying panels flat is they only produce about 50% of rated power. Actually more like 40% in the winter and maybe 60% in the summer.
Then the PWM charge controllers only let 2/3 of what the panel produce through to the battery. So in the winter you can be getting as little as 24% of a panels rated power.
Using a PWM charger on a vehicle based system is a waste of time and money.
But if you use a MPPT controller you get around 98% of what the panel produces.
