Old 08-27-2016, 01:17 PM   #10 (permalink)
aerohead
vena contracta
The drag of a flat plate opening will be akin to a flat plate (Cd 1.11),with massive flow separation which actually chokes off the airflow within the passageway,(known in fluid mechanics as a vena-contracta entry loss) worse than with the cuboid (far left) below
Even with a sharp-edged pipe opening we get the vena contracta loss (the yellow regions of turbulence are choking down the flow)
If the inlet is bell-mouthed (like inside the throat of a carburetor's venturi) the loss is completely eliminated,leading to the most aerodynamically-efficient inlet.
The Following 3 Users Say Thank You to aerohead For This Useful Post:
BamZipPow (08-28-2016), MJamson (08-28-2016), Xist (08-29-2016)
