Old 08-27-2016, 10:28 PM   #15 (permalink)
freebeard
Tiny little pictures.
Is the charge controller beneath the panels in the rack 'corral', or ahead of the rack?
With a prop rod at the center front and back you could latch/hinge it to either side, you have two choices and it wouldn't have to lift as high.
When you decide that wood is too heavy there is PolyMetal. It weighs 1/10th as much. And it's pre-finished.
For load? An LED light bar across the front, and a 110v AC outlet.
