Old 08-28-2016, 08:04 PM   #29 (permalink)
LittleBlackDuck
LittleBlackDuck's Avatar
CT - '11 Lexus CT200h Luxury
Originally Posted by DragBean View Post
My vehicle has a 250 Watt panel on top. And at 14.6V even a good battery is drawing a couple amps or so..
Actually, if you look at how a battery should be charged, if it is at 14.6V and drawing 2A, it is ether a huuuugeee battery or you are abusing it badly by overcharging the heck out of it.
A good starter resource is Battery University - table 7 states:
"Subject to corrosion and gassing. Needs water refill. Not suitable for charging at high room temperatures, causing severe overcharge." for charging to 2.45V per cell (14.7V).
Charging Information For Lead Acid Batteries
It becomes non-negligible when you are trying to run the entire car off Solar
Also, with an efficient EV using in the order of 250WH/mile and solar production being approximnately 6 x panel capacity per day (in WH), this is an admirable aim but totally impractical unless you drive less than 6 miles per day and park in full sun on a slope where the solar panel has the proper orientation.
Simon
The Following User Says Thank You to LittleBlackDuck For This Useful Post:
Xist (08-29-2016)
