Originally Posted by DragBean
My vehicle has a 250 Watt panel on top. And at 14.6V even a good battery is drawing a couple amps or so.. It becomes non-negligible when you are trying to run the entire "electronics of the" car off Solar
My goal here is not to get into arguments with people.
But if it makes little black ducky happy I changed the what I said to running the entire "electronics of the" car instead of entire car.
As far as the battery goes, the draw off the alternator onto a fresh fully charged battery is still going to be at least amp. May only amount to 1/20th to 1/10th of a hp in electrical power (that you're gaining all the time), but shedding the type of load plus 20 lbs of weight (more importantly giving me more engine bay space) is a plus I'll take.
