Old 08-08-2008, 10:48 PM   #30 (permalink)
donee
- - '10 Toyota Prius III w/Navi
Hi Otto,
Most boat engines injest water into the cooling passages of the engine, and pump it out. So, they are direct conduction cooled. No need for a heat exchanger at all, although bigger engines have a water to water heat exchanger. That is why an outboard motor can be so light-weight. Ever seen a radiator on a boat? Nope. Its just the engines down in the engine bay.
