Old 09-01-2016, 08:17 AM   #119 (permalink)
Stubby79
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
If it's a slow-blow fuse, it should be fine at 250 amps. Those ANL and such tend to be slow-blow, assuming that's what the OP went for.
2 gauge wire should be fine, assuming your battery isn't border-line for being able to just kick over the starter. Welding-wire used for welding at 2 gauge is rated for 400 amps at up to 50' of it. Not sure if it's been mentioned, but you should probably run a negative wire to the engine block as well, not just straight to the chassis, to keep voltage drop to a minimum. If you're running it to both, it could potentially be lighter gauge.
The Following 2 Users Say Thank You to Stubby79 For This Useful Post:
California98Civic (09-01-2016), pletby (09-01-2016)
