Old 09-03-2016, 12:54 AM   #25 (permalink)
Chrysler kid
5 pin sensor
Zippy - '96 Honda Civic Hx
90 day: 40.77 mpg (US)
Boring - '11 Ford Fusion Sel
90 day: 21.88 mpg (US)
My red hx is worn out as well. It's getting 32mpg city, I've never gotten that low in an HX ever. My black car will get 38mpg without sleenizing but it's a low mileage car
I'm not even going to bother with compression testing my red car, probably going to be low too. one thing I am going to change however is the catalytic converter. I'm not getting a check engine light however it has a gas stench out of the tail pipe.
I mention that because I can tell you re used the old factory 300k mile catalytic converter. New cats are 2 pieces compared to the factory one piece
Cheers
The clear cam cover holds up pretty well over time. It gets a little dirty after a while but no yellowing or anything
My red car is at 242k miles and has a very noticeable lack of power compared to my 159k mile black hx, which should not be the case since I have tons of new parts on my red car. Which leads me back to the poor performance of the red car.
Red is actually a California spec ecu, black is federal. Putting in a federal ecu did not increase lean burn in red, or gain any gas mileage, and the car still can't maintain lean burn.
The most likely causes for reds problems:
Clogged egr port on cylinder head disrupting egr flow, or filthy intake manifold
Poor catalyst effeciency disrupting primary oxygen sensor readings
Current: 1997 civic lx
Past: 1998hx/1996hx/1997lx/1997hx Cali/1997hx
OG lean burn member
My civic thread
The Following 2 Users Say Thank You to Chrysler kid For This Useful Post:
98hxman (09-03-2016), Joggernot (12-12-2016)
