Originally Posted by Frank Lee
FWIW I'd disable the valves on cyls 1 and 4 and pull the non-working pistons and con rods. Then I'd have to plug the oil ports on those two crank pins. I'd want cyls 2 and 3 to be the working cylinders because the rocking couple would be minimized. I don't think I'd try it on a turbo engine unless as someone said earlier a right-sized turbo was fitted. Stock flywheel should suffice. Stock manifolds too. O2 too. I'd put resistors equal in resistance to the injectors on injector leads 1 and 4. Might be naive but if ECU listens to the O2 sensor the mixture richness should be fine in spite of the reduced air volume moving through? It should be able to highway cruise just fine, although acceleration will be glacial vs stock. Fuel economy should be improved but not doubled; my WAG estimates better than 15% but less than 50% improvement. Mind you I haven't done this but this is how I'd start off.
Pulling the pistons like this would result in a huge primary imbalance as well as the secondary rocking couple. The thing would be like a pogo stick at idle and most likely self-destruct catastrophically at higher revs du to the bending forces on the crankshaft.
Mixture would be totally out of whack too, as the ECU would use injector opening times based on four holes being opened instead of the two operating injectors. The oxygen sensor would detect this and probably throw a few codes to boot.
Simon
